Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 77 C10 stepside electrical problems
Old 12-04-2012, 09:01 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Don't use the remote starter, I would try grounding it directly to the frame...10 years ago I had a Cadillac Fleetwood that I couldn't get to run properly, I took it to 3 or 4 reputable mechanical shops, they tried everything and about $1,000.00 later it still ran like crap...I thought about it for a while and took a battery cable and grounded the engine to the frame and it ran like a champ. I don't know if this is going to solve your problem but, if everything has tested out positively it's worth a try...sure would be a cheap fix if all you need to do is ground it to your frame.
Let me know if it works for you, here's hoping.
Ray
