77 camaro floor pan replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 05:22 PM
Last journal entry: few more pics
I have a 77 camaro and it needs floor panels on both sides. In the toe of each floor has alot of rust, and what i was going to do is buy full length and only use what is bad on my floor. Anyone have any advice on where to get the replacement panels, and the proper way to measure the panels for a measure 2 cut once fit. This is my first time doing floor panels so any info would help thanks for reading
Old 04-11-2011, 05:39 PM
I wouldn't buy a complete floor if all you need a toe kicks.Thats a lot to waste and are expensive compaired to partials.Start with National Parts Depot or Year One to get started.
Old 04-11-2011, 09:02 PM
should i use like a card board template to get the piece i need or measure the new panel, and just cut to fit the whole panel
replacement floor pans screwball Body - Exterior 1 03-22-2008 10:36 AM
Floor pan replacement DonC Body - Exterior 5 01-03-2008 05:15 PM
floor board replacement camaroboy1991 Body - Exterior 3 05-21-2007 03:52 PM
floor pan replacement panel 51 ply wmn1113 Body - Exterior 1 01-02-2006 10:29 AM
floor pan replacement richardson110 Interior 1 05-05-2004 06:05 AM
