77 catalina engine swap
I have a 1977 pontiac catalina witha 301, and i want to put a chevy 350 in. Should i but a different trans to bolt up to the 350 or will my pontiac trans bolts up? will a chevy trans fit into my transmission mounts?
They make transmission adapter plates. Your frame should already have the holes in it for the Chevy engine mounts.
General Motors had two transmission bolt patterns (at least with what we commonly discuss here)
Chevy had its own pattern. All Buick, Olds, Pontiac, and Cadillac shared the same pattern - different from the chevy. That is why you'll often see transmissions advertised as "chevy" or "BOP" If you're putting a chevy engine in place of a Pontiac 301, you'll either need to pony up for an adapter kit, or buy a chevy version of the same transmission you have now. |
Go pontiac
The 301 is a low deck height pre-corporate pontiac. If you run a 326-455 pontiac instead of the chevy. I believe your engine mounts and I know your tranny will bolt right up i would go that rout. Then it would stay all Poncho
A Pontiac 400 or 455 will cost more than a 77 Catalina is worth.
at one time, I had the chance to buy a '78 Olds Cutlass cruiser custom ( loaded 4dr wagon ). that was pretty nice for $400. had a 307 in it, but the owner also had a 455 he was willing to sell with it for another $500, or $700 installed ( shop owner ).. some work to that 455 and the car would have been 1 quick grocery getter.. passed on it tho.. but it would have been a sweet car for $1,100
| 53 Packard Clipper Engine Swap? | 53packard | Engine | 16 | 07-06-2010 04:32 PM |
| Engine swap for Blazer S10 | ducktruck87 | Engine | 31 | 07-01-2010 08:44 PM |
| Engine Swap for Crown Vic | edge | Engine | 12 | 11-03-2009 09:38 PM |
| 326 firebird engine swap with a 400 engine...is it possible?? | greg67 | Engine | 7 | 11-08-2003 03:34 AM |
| 77 chevy engine temperature sensor location??? | 77chevy400 | Engine | 4 | 07-09-2003 01:51 AM |
