77 chevy truck no rear brakes bad proportion valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 07:47 PM
I'm geting my 77 chevy shortwide back on the road and I got new brakes all the way around truck a new master cylinder, well I bleed everything the way I usually do bench bleed master, then.started with the furthest wheel from mc them next furthest so on well the peddle didn't feel right so I opened the front line on the master to cut out front brakes to check the rear brakes and had no rear brakes so I took the rear line on master off completely partner held finger over hole it built up enough presser to blow his finger off and spray brake fluid out so I no in getting out of master but is their a way I'm messing up with the proportion valve please any advice is greatly appreciated its been a twoo years project and as always one thing after another wife is about ready to kill me
Old 09-13-2011, 06:49 AM
I have ben doin some reading on the proportion valve says to push the button under the rubber boot but will that help with the no pressure to rear or could I have a defective mc thank you for your answers
Old 09-13-2011, 06:58 AM
455olds's Avatar
I think defective master cylinder.
Old 09-13-2011, 08:26 AM
The only thing that makes me think the master is good is when I undid the front lines held finger over rear line hole after a few pumps to get air out it built up pressure so I its coming out of master cylinder maybe I have air traapped by the proportion. Valve
Can I use a truck proportion value and my car. oldtimercarnut Suspension - Brakes - Steering 2 07-04-2011 05:37 PM
proportion valve 57chev Suspension - Brakes - Steering 4 08-30-2007 07:13 PM
1988 chevy truck, rear suspension and brakes cxpcman Suspension - Brakes - Steering 6 05-08-2006 07:43 PM
67 chevy truck disk brakes ,HOW? oklowride Suspension - Brakes - Steering 4 11-15-2005 11:53 PM
brakes 51 chevy truck bill smith Suspension - Brakes - Steering 1 05-01-2003 04:34 PM
