77 f 150 duel fuel tank capacities? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2005, 07:43 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Hey Y'all
I got the 77 ford pu running and just about everything works but the front fuel Gage i ve been reading all over and in the owners manual but can't seem to fine how much fuel the front and rear tanks hold but i did find a web site that has replacement sending units
as always Thanks in advance
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 12-03-2005, 04:23 PM
Rob Keller's Avatar
Wiki Edits: 38
update I had to replace the small line and the fill tube on the front tank and for the record
the front tank holds 21 gallons and
the rear holds 19 gallons
now If i could get the rear tank to quit pukeing fuel out the filler tube through the vent in the cap when its on a slight tilt to the drivers side
SR66
I'm not prejudice, I hate everyone
"SlowRide66"
Carb size to small???? brainsboy Engine 50 08-14-2005 05:04 PM
Edelbrock performer fuel pump on a 77 gmc 400CI? 77chevy400 Engine 1 07-09-2003 01:17 AM
leaky fuel tank CaptnSkull Engine 11 01-24-2003 08:07 PM
fuel tank troubles 65galaxie500 Engine 9 11-18-2002 07:54 AM
Fuel Pressure Variance slomotion Engine 2 04-02-2002 02:25 PM
