'77 F100 Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2010, 03:47 PM
Last journal entry: 69 Mustang
'77 F100 Rearend
I've read that positive lock differentials are dangerous for daily drivers. I have a '77 F100 without positive traction. I'm having the gears changed from 2.75 to 3.50. I would like to have positive traction. what would be the best, least exspensive, and safest way to do this without changing the entire axle. Or is changing the entire axle the best way to go?
Old 07-04-2010, 04:13 PM
poncho62's Avatar
Wiki Edits: 5
A posi traction rear end still staggers the wheels speeds around corners....there are clutches or other devices in there to do that.....I think you are referring to a spool rear end when you heard about not being safe,,,,,That is a device that totally locks the 2 rear wheels together, not allowing different wheel speeds for cornering. Those are used mainly on drag racers.
Old 07-04-2010, 04:23 PM
hp246's Avatar
The old limited slip rear ends make winter driving on icy road a real challenge. Dry pavement not so big a deal.
Old 07-04-2010, 05:36 PM
Re
Thanks for the info.
Old 07-04-2010, 05:40 PM
big gear head's Avatar
High Performance Rear Ends
I've sold a few Duragrip differentials for the 9 inch Ford lately and I just installed one in my Camaro last week. So far it's working great. These are MUCH stronger than the original Ford Traction Lock. A little bit of grinding inside the case is required sometimes for clearance of the thicker clutch cover on the Duragrip.
Rearend for a 1956 F100 Harleyvato1963 Hotrodding Basics 18 09-15-2008 09:20 PM
77 f100 rjent Body - Exterior 2 02-12-2007 09:05 AM
77 Camaro rearend thumpercamaro Transmission - Rearend 2 06-04-2006 11:29 PM
Finding replacement body parts 77 F100 sbilbrey Body - Exterior 3 12-01-2005 06:57 PM
53 F100 rearend What do i need? 53F100 Transmission - Rearend 7 01-24-2003 04:29 AM
