Thread Tools Search this Thread share on Facebook
  #1
Old 11-14-2011, 01:32 AM
1996thunderchicken's Avatar
1996thunderchicken 1996thunderchicken is offline
ALL AMERICAN MADE
77 nova rearend
i have a quick questoin i got a 1977 chevrolet nova and i have been trying to find out who would make a ford 9inch for my application or would one from an old camaro work the reason im askn is that i have a ten bolt rearend and the guy i bought the car from said that this one takes speacial seals
Register now (free) or login to remove ads
Old 11-14-2011, 01:43 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Not sure what special Seals He would be talking about.
What Rear does the Nova have? 7.5" or 8.5" 10-Bolt?
http://www.novaresource.org/axle.htm
9" Rears >> http://www.quickperformance.com/Products/rearends.htm
Old 11-14-2011, 05:46 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
Hopefully you have the corporate 10-bolt 8.5" diff in your Nova. If you do, the rear end is sufficiently strong for most any street driven combo w/a good set of 30 spline axles and a posi carrier like from Eaton.
If you find that yours is a 7.5", you can use a 8.5" from a 1975-'79 Nova or the 1971-'81 Camaro/Firebird. The Pontiac T/A came w/a posi but the ratio might not be what you want and the carrier can be a 2-series. Also be sure the diff you choose is a 3-series if you plan on a performance ratio. The 8.5" corporate rear end uses a 2-series differential for 2.41 and 2.56 gears and a 3-series differential for 2.73 and lower (higher numerically) ratios.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "77 nova rearend"
ThreadThread StarterForumRepliesLast Post
New rearend in my 71 Novawfd102Suspension - Brakes - Steering212-20-2007 08:20 AM
63 nova rearend63novamnTransmission - Rearend1512-17-2006 01:37 PM
Nova rearendhotrod66_57Transmission - Rearend407-24-2004 04:43 PM
nova rearendottisTransmission - Rearend312-06-2003 07:13 PM
Rearend For NovanovachadTransmission - Rearend305-29-2003 03:16 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
