With what you are trying to accomplish I would find an old hobbystock/streetstock circle track chassis that used a camaro clip. cut the cage off the fabricated frame and put it under the car.
these cars hae been done so often now a days, if your low buck , places like comp eng. has rails that fit your car. drilling out old spot welds on the 14 gauge sheet metal is pretty easy, and welding in a back half is pretty easy, if you have fab skills.
like i tell all my other buddys with f-bodys... GET A REAL CAR
What do you plane on doing with the car!?? My brother has a stock 1977 trans am and it handles great on the road. I would replace all the bushings with poly and throw in moog ball joints and tie rods. I would keep the stock springs and go with some high performance shocks. The 2nd gen f-bodys are not ridged at all and benefit greatly from sub frame connectors.
I wouldn't remove the rear frame rails unless they're rotted out! It's all about how much time and money you want to spend. I have a '68 firebird (which i should be posting my build on her ) that I designed the rear 4 link in solidworks and have building all the pieces in the machine shop.
The right rear rail might as well not be there, I was able to tear the bottom off with my hand. The left one seems to be alright but, I might as well replace that one if do the other. If I decide to just replace the rails. And yes, either way I'm am going to tie the frame up.
| 77 trans am 305 hop up | 84f150guy | Hotrodding Basics | 8 | 01-10-2009 08:33 PM |
| 1962 Cadillac Trans | colwoodshane | Transmission - Rearend | 6 | 10-12-2008 12:22 PM |
| Anybody out there running a stand alone trans cooler? | Mad_Max | Transmission - Rearend | 13 | 04-16-2008 10:24 AM |
| AXOD Ford trans rebuild advice. | 4 Jaw Chuck | Transmission - Rearend | 22 | 03-16-2004 05:37 PM |
| need help getting rid of air conditioning on a 77 Trans am | Hot Rod/SS | Engine | 0 | 01-23-2003 09:44 AM |
