Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 77pontiac door hinge
Old 02-14-2012, 05:40 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Or you can just get a bigger bushing and drill the worn hole out bigger ,just make sure the pin fits the bushing before you get started. You can even use a chevy truck bushing set with the truck pins but the pins will need cutting
