Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 77pontiac door hinge
Old 02-15-2012, 12:43 PM
stealthninja stealthninja is offline
the reason I asked was I currently don't have enough money to replace both and the car is still in transit to my house from AZ. I will try all of the above advice once it arrives. I am almost positive that the passenger side just needs pins and bushings. but the driver side needs me to slam with all my might just for it to close all the way. I hope I don't need to weld and do that stuff with the striker. I just want to be able to shut the doors without slamming and them to seal so no water leaks. The doors have all new seals but they still leak water through the tops. Its a hardtop so no convertible or T-tops to worry about.
Thank you very much for you time and recommendations. I will post a repair log asap.
