Those doors are long and heavy. I worked for a Pontiac dealer when that car was new they never closed easy when new! If you put the window down a little the door will close easy. Your lucky you don,t have t tops they always leak. At least here in Seattle where it rains more than not! Putting in the bushings and pins isn't hard you can do it. If you use a floor jack with a blanket folded up for padding to support the door with it wide open it works good.
