Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 77pontiac door hinge
  #16 (permalink)
Old 02-23-2012, 05:39 PM
diety motorsports diety motorsports is offline
door hinge pin and bushings
if your gonna do this, you will want the kit, the pins and the bushings, period. also a gm door spring tool to remove and especially install the spring back in. You won't be able to get one of the pins out, without the spring outta the way.
