78 350 runs rich - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-09-2010, 03:44 PM
thx Tech & sorry glhx, I thought you had a speed demon the whole time...
  #17 (permalink)
Old 06-10-2010, 10:28 AM
so far the tips i have have fixed the problem. advancing the timing made it run 100% better. the first plugs worked well. when i went to the hotter plugs i had to richen the mix. there is still some tuning to do. the drivers side still runs a little rich, but i think i can fix that. I am having some trouble with cold starting. i have to pump it 5 or 6 times to get it to start and it doesnt want to idle. even when i turn it off for 5 minutes it still is a little low on idle.
some thing ive checked into that may cause this might help. ohming the plugs and wires like you said. replacing the wires to fix any cross sparking. then mess with the fast idle. may need help with that. i will make sure the ignition system is right before i mess with the fast idle
350 won't start, backfires, starter smokes, runs rough... 1970customcamper Engine 3 09-08-2009 08:57 PM
Hi my name is Rich and I am a craigslist addict( 350 build) candrive55 Engine 3 06-15-2009 11:14 PM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
78 camaro 350 trans with 427 myrl Transmission - Rearend 7 02-18-2005 08:49 PM
My 350 SBC (HO Engine) Runs hot barkmmi Engine 3 07-13-2003 09:21 AM
