78 Buick Skylark - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2003, 03:52 PM
njbloodline666's Avatar
I Love VTec
78 Buick Skylark
i have 77 6cyl nova, i am coming into possession of a 78 skylark, they look like they have the same chassis, so i was wondering if the drivetrain would fit into my car, it would be alot easier to use that drivetrain than to go lookig for a trans driveshaft and rear end that would support my smallblock
Old 08-12-2003, 07:47 PM
dklong's Avatar
the skylarks for that year mostly used chevy power train, so everthing should work unless it has a pontiac or buick engine then you would have too change engine mounts and the wire harness and maybe drive shaft if has a th400 and exhaust system
Old 08-12-2003, 08:13 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
The nova and the skylark should be the same in terms of driveline components and suspentions.
They are both X-bodies.
Old 08-12-2003, 10:31 PM
If the rear ends are the same (7.5" or 8.5"), everything should bolt up, as the 78 Skylark is just a Nova clone. I also have one of each. The Buick does have noticeably softer springs and much more padding under the carpet. My 77 6-cyl. Nova has the 7.5" rear end, while my Skylark (305) has the 8.5", which needs a shorter driveshaft (around an inch, I think). Both have T-350 trannys.
Old 08-21-2003, 11:57 AM
I Love VTec
jim, i should be able to use the driveshaft from the buick as well as the rest of the drive train...correct?
Old 08-21-2003, 04:30 PM
Yes. Here's a picture of a 7.5 & an 8.5 side by side: http://malibunorth.freeservers.com/RearID.html . Look at the projections on the bottom of the case at the 5:00 & 7:00 positions. If the Buick has the 8.5, just use the Buick driveshaft. I think Skylarks only came with V8's, so it should be the big one. Now for the bad news. 305 automatics like mine came with a 2.41 rear gear , so be forewarned. Good excuse for a new posi, right?
Old 09-28-2003, 08:57 PM
I would like to know if you like to sell th edriveshaft out of the 78 Buick Skylark for a resonable price...I have one, had 2 and ripped the custom made one out and ****ed it up..so I had to use the other one..ony how I sold it ..but I still need a shaft for the other one.. If not do you know some one who has one out of a buick..same year/style or a 75-79 nova they are the same chassy and x-frame so I figurre the driveshaft may work..
lil_linkin_04@yahoo.com
