78 camaro 350 trans with 427 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2005, 06:23 PM
New Member
Hey Guys, I want to use a stock 1969 427 in a 78 camaro that has a stock 350 transmission and 308 rearend. Will they hold up and what kind of performance can I except. Thanks for the help.
Old 02-03-2005, 06:30 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
no problem
There should be no problem. The rear end will hold up as long as it doesn't hook. Slicks would be a definite no-no. Tranny weak link will be the front sprag. Adding a tranny cooler may help.
Old 02-08-2005, 07:18 PM
New Member
Thanks for the help. What converter should I use.
Old 02-16-2005, 07:26 PM
Hankster2's Avatar
427 w/350 tran
Myrl
My brother & I ran a 74 Nova - 427 -L88 with a beef up 350 Tran
w/shift kit etc. 1996 thru 99- 8 " converter - 29" M/T 9" tires Car ran 1/8 mile
7'0 and 11'0 1/4 mile w/speed 121 mph Gears 4.56 12 bolt
We are still running the car with 496 w PowerGlide- 32x 14.5 M/T
gears 5:13 12 bolt Chev Best 1/8 6:17 111 mph
Hank
Old 02-17-2005, 05:10 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
From what I can remember GM always put a TH-400 behind a big block.
Sure a TH-350 can survive in the same place, especially with minimal care.
The rest of what you are asking "what can I expect", I would bet the farm on it giving you a big grin, especially if you had driven it with the original engine much.
Old 02-17-2005, 08:28 PM
bracketeer's Avatar
489 Lemans
my philosophy
Don't fix it til it's broke. When, and it probably will break. Fix it with some beefed up parts. Better brand name friction plates. Hardened sprag. Good convertor with balooning plates. You may get a year or more out of the tranny.
Old 02-18-2005, 05:49 PM
jakeshoe's Avatar
I would use the TH350. It WILL hold up fine to a BBC but I would install a TransGo reprogramming kit to dual feed the direct clutches with the BB torque.
It will also firm up the shifts. Probably double the life of the trans....
Old 02-18-2005, 08:49 PM
New Member
308 rearend
Thanks for all the suggestions. Is there away to make a 3:08 rearend perform better, or should I just try and find a 3:73. I also want to use this car as a daily driver.
