Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 78 camaro/700r4/driver shaft
Old 12-22-2011, 01:13 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
You wont find a DS the correct length at a Yard. Just have yours Shortened & Balanced and new U-Joints installed where the Zerk fitting is under compression load or the correct way. You wont need super duper fittingless U-joints at your power level.
The DS Shop will tell you how they need you to measure for length.
