78 camaro project
I'am restoring a 78 camaro, and I plan on using a small block 400. I would like to use factory heads, intake and exhaust manifolds. Can anyone give me some casting #'s that would produce the best performance for this build. They Can be from any year or make. I could also use some help with the cam and carb selection. Thanks for the help.
casting #s
Pretty well all the casting #s can be found here on Mortec. With a 400 sb with flat top pistons, you cannot use any head with less than a 70cc chamber. You are best to stick with a set of 70cc 350 heads and drill the steam holes yourself.
The use of stock intake and exhaust will limit you to the use of something along the lines of a performer cam or an xe268h at best. Carb selection will be limited to spread bores, such as the Edelbrock or QJet. |
Thanks for the help. If I use an aftermarket intake and headers, which ones would you recommend and how much of would it help. At present the rearend is 2:73; I will probably change latter to a 3:55 or 3:73. I will use the car as a daily driver. I'am trying to make a low 14 sec 1/4 car that is fun to drive and reliable I'am I asking to much and would a mild stall converter help. I want to keep the car looking stock but not run and sound stock. I have a pair of double hump heads. but the don't have the accessory holes;can they be tapped.
means to an end
I prefer Edelbrock intakes and Hooker headers. What size are the heads you have?
| Can I make my 78 firebird into a Camaro? | Suckingas | Body - Exterior | 9 | 06-28-2010 11:06 PM |
| newbie needs help work an 82 camaro project! | aiver11 | Introduce Yourself | 21 | 02-12-2008 09:28 PM |
| Camaro Dash project | revolver682 | Interior | 1 | 01-24-2005 10:28 AM |
| 78 camaro to t top 87 monte carlo help | isleofwight | Engine | 3 | 06-28-2004 09:29 PM |
| 78 camaro suspension | andybird | Suspension - Brakes - Steering | 7 | 07-14-2003 04:43 AM |
