78 camero subframe install on 58 apache - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2009, 09:32 PM
I am getting ready to install a 78 camero suframe on my truck
does any one have info on what angle the subframe should
sit at if i place an angle guage in the crossmember, or another
part of the frame. I have already removed the cab mount brackets.
Old 04-14-2009, 08:24 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Flat part of the X-member (underneath?) is usually dead flat front to back when in driving position.
Old 04-14-2009, 10:42 AM
propaneburner's Avatar
Last journal entry: Artillery wheels
The best way to do this (in my opinion ) is to check how that year camaro was measured.
The place where to measure is the upper A arm bracket, out of my head it needs a 6 degree angle, with your old chassis leveled out to 0
This was the latest one i did, already four years ago.
Wander
Old 04-14-2009, 12:58 PM
DOUBLEDICK's Avatar
go to the hotrodders lounge and find "55 to 59 chevy truck owners" thread. several guys have posted there doing this same swap .good luck with your project
4 link subframe install ucmung Suspension - Brakes - Steering 5 04-10-2006 09:05 AM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 12:17 PM
Fender install problem 59 apache billg_69gmc Body - Exterior 3 07-06-2004 05:18 PM
taking dash apart to install radio 78 camaro sevndoldscutlas Interior 3 02-25-2004 08:23 PM
coil spring install on camaro subframe kid Suspension - Brakes - Steering 3 08-25-2003 06:26 PM
