78 chevy 350 heads to a..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 11:12 PM
i have cracked 78 350 block and i want to put the 305 heads(from a 87 monte ss) cam and intake on a 92 5.7 tbi truck engine, is this posible?
Old 08-29-2010, 12:40 AM
SSedan64's Avatar
The 305 Heads are 58cc, 350 TBI Heads are 64cc Chamber. This will increase your compression ratio about .5 or 1/2 a point. May or may not require higher octane fuel. I'm not sure how the TBI computers respond to more Cr, someone will know.
Old 08-29-2010, 02:44 AM
badknuckles's Avatar
you talkin to me?
i have done this previously, i put 305 h.o. heads on a l98 engine to raise compression and it backfired. my compression ratio was ridiculously high causing pinging and the engine was sucking at higher rpm's. i would get smaller chambered 350 heads.
Old 08-29-2010, 05:53 AM
SSedan64's Avatar
The SSMonte HO305 Heads also have smaller Intake valves @1.84"
Need Help FAST!!!!!!!!!! millertime85 Engine 14 06-25-2008 07:01 PM
Need an opinion on chevy 350 heads MTBnRC17 Engine 1 04-06-2008 09:56 PM
chevy 350 heads on 305 coolcars58 Engine 1 05-21-2006 12:23 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Longblock Chevy 350 Crate: Cam and Head concerns 360Camaro Engine 18 08-05-2003 03:51 PM
