78 chevy 4x4 with a 12 bolt rearend questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2013, 03:30 PM
Last journal entry: 81 regal swap project
I have a 78 chevy 4x4 with a 12 bolt rearend and I need to replace the carrier and I guess there are three different sizes, like 8.625, 8.75, and 8.825? I can't remember exactly. How do I tell what I have or does it matter? Please help! Thank you
Old 07-02-2013, 03:51 PM
techinspector1's Avatar
Wiki Edits: 326
Order an original shop repair manual here.....
Faxon | Shop Manuals for Car & Truck Owners | DIY Service, Repair or Maintenance
It will have all the information you need to fix the problem and how to do it.
Old 07-02-2013, 04:14 PM
There is a 2,3,and 4 series carrier for the 12 bolt truck differential.
You can tell them apart by what gear ratio is installed.
2.56 and 2.73 is 2 series
2.76-3.42 is 3
3.73-4.10 is 4
Old 07-02-2013, 07:15 PM
big gear head's Avatar
High Performance Rear Ends
The Chevy truck 12 bolt has a 8 7/8 ring gear. There is only one Chevy truck 12 bolt. There are no other sizes. There are 3 different series differentials like Imsport said. Be sure that you get the correct one for the gear ratio that you have. You must check the backlash before you remove your differential and set the backlash back the same when you install the new differential.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
4x4Chevy (07-02-2013), Crosley (07-02-2013)
Old 07-02-2013, 08:45 PM
Big gear head thank you that is exactly what I was lookin for! Much appreciated
axle, bolt, carrier, chevy
69 chevy 4x4 frame questions Timothy Robbins Hotrodding Basics 1 05-22-2011 07:58 AM
86 4door chevy 4x4 questions/ideas 86Crewcab General Rodding Tech 2 06-14-2010 05:14 AM
Gm 12 Bolt Rearend ID number questions Salinas, CA Transmission - Rearend 4 03-07-2010 01:38 PM
14 bolt 4x4 differential questions tyson snyder Transmission - Rearend 2 02-27-2010 08:06 PM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
