78' Chevy C10 Pickup transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2011, 09:29 PM
I have a 78' Chevy C10 Pickup, 350 SBC, not sure what Tranny I have. Maybe 350. I'm still new and this is my first build. Everything was running fine yesterday, near perfect except the small leak I have in my exhaust Manifold due to bad gaskets.
So yesterday, my tranny dipstick did not show it was full, and I checked while it was hot. A friend told me today that it could be an after market dipstick that did not reach all the way. I added 1 QT of Fluid. Did not drive it after that.
Today, I started up, let it warm up, and started down the street when my fluid started leaking, actually what happened was the hose that connected to my radiator that runs tranny fluid through it blew off like it was under serious pressure. I pretty sure I lost all of my fluid. I parked my truck and hooked the hose back up and my truck would not accelerate that good. I let the truck sit all day.
So this evening I added 1 QT of fluid and the truck started up fine. The dip stick still shows that more needs to be added. I tried to drive my truck and it does not move at all after I shift. When I put it in reverse it shakes a little bit, like it wants to move but it doesn't.
First, I think I added fluid when it did not need any and that is what caused the hose to be under pressure and blow off.
Now, I think I don't have enough fluid. I'm not too knowledgeable on Trannys. How much fluid should I add. I found different responses on the internet, anywhere to 4 qts, to 12 qts. If I need 12 qts, then I need to add 11 more and that will be quite expensive as each qt is 7.99 at AutoZone.
Please educate me and tell me what I did wrong to begin with, for example if I added to much, is what I experienced typical, and next, is my truck not moving because I don't have enough fluid. I hope this is not a Tranny problem that needs to be fixed. New Starter, and Torque Converter, and Flex Plate, but Could I have messed one of those up?
Old 08-08-2011, 03:43 PM
sqzbox's Avatar
My pipes are my music
Just 2 qt's low is enough to keep your truck from moving. Keep adding it untill it shows on the dipstick and it should start moving. After it gets warm from driving, then add it to the full when hot mark. Always check the fluid with the engine running in park. Good luck.
93 chevy pickup 4L60E transmission, no 3rd or 4th Jlee Transmission - Rearend 2 06-17-2011 07:04 AM
Transmission problems? Fast 4 Door Transmission - Rearend 4 03-28-2010 01:19 PM
1972 Chevy Pickup guage problems Maxwell007 Electrical 0 03-06-2010 03:00 PM
66 chevy pickup start up problems caboose8 Electrical 4 08-07-2006 07:15 PM
64 chevy pickup transmission slimfatboy07 Transmission - Rearend 1 05-24-2002 08:52 AM
