'78 Chevy Luv truck won't stay running - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2003, 05:18 PM
Jmark's Avatar
Here's a question for you old timers ( like me ). "78 chevy luv truck, 4cyl, turn the key and it cranks and starts, let go of the key and it dies. Ign switch was my first thought and has been replaced, but didn't fix the problem. Key and switch are one unit in the column so adjusting the switch is out. Does the module have a "resistor" for "run" and use full voltage on the start mode? Been a long time since I"ve worked on one of these wrecks. I"m open for any ideas. Thanks
Mark
Old 10-07-2003, 06:09 PM
DoubleVision's Avatar
I ran into this problem in a 65 Chevy and didn`t bother to trace it down, all I did was run a toggle switch to the distributor as the customer insisted. the wiring on this truck was a mess so I happily just did as he asked. good luck J.
Old 10-08-2003, 07:04 AM
Wrencher's Avatar
Sounds like you lost the ignition side on the starter solenoid?
