-   -   78 chevy silverodo rocker arm bolts (http://www.hotrodders.com/forum/78-chevy-silverodo-rocker-arm-bolts-209191.html)
Admeril 11-22-2011 08:46 PM
what can i do when the pressed bolt comes out? what options do i have? :confused:
BOBCRMAN@aol.com 11-22-2011 08:53 PM
If the STUD comes out. The most practical thing to do is buy a threaded repair stud. Thread (tap) the existing hole, place sealer in the threads and screw repair stud into the hole.
Admeril 11-23-2011 04:59 AM
Thanks for the info. I thought thats what i was going to have to do. whould you replace all of them or just the ones that are loose
gerbsinmd 11-23-2011 06:21 AM
If you have some that are loose, the rest won't be far behind. I'd do them all.
techinspector1 11-23-2011 01:18 PM
Excessive valve spring pressure is what pulls them out, anything above valve open pressure of about 270 lbs will do it. The inexpensive way to prevent pullout is to use a pinning kit....
http://www.speedwaymotors.com/Rocker...ign=GoogleBase
http://www.race-mart.com/Mr._Gasket-MRG-806G.html
