78 chevy silverodo rocker arm bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2011, 08:46 PM
what can i do when the pressed bolt comes out? what options do i have?
Old 11-22-2011, 08:53 PM
BOBCRMAN@aol.com's Avatar
If the STUD comes out. The most practical thing to do is buy a threaded repair stud. Thread (tap) the existing hole, place sealer in the threads and screw repair stud into the hole.
Old 11-23-2011, 04:59 AM
Thanks for the info. I thought thats what i was going to have to do. whould you replace all of them or just the ones that are loose
Old 11-23-2011, 06:21 AM
gerbsinmd's Avatar
If you have some that are loose, the rest won't be far behind. I'd do them all.
Old 11-23-2011, 01:18 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Excessive valve spring pressure is what pulls them out, anything above valve open pressure of about 270 lbs will do it. The inexpensive way to prevent pullout is to use a pinning kit....
http://www.speedwaymotors.com/Rocker...ign=GoogleBase
http://www.race-mart.com/Mr._Gasket-MRG-806G.html
TPI 350, in a 87' silverodo gofastz Hotrodding Basics 20 01-30-2011 11:07 AM
New Member-silverodo silverodo Introduce Yourself 1 07-20-2007 01:28 AM
Loctite on Rocker Arm Studs and Head Bolts? Bakdok Engine 13 03-30-2004 08:25 PM
Rocker bolts philPKP Engine 4 10-02-2002 04:32 PM
