78 Chevy stepside max tire width - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2003, 01:18 PM
Can any body tell me what the maximum rear wheel and tire width can be put on a 78 Chevy stepside WITHOUT cutting the frame and WITH moving all suspension inside the frame? Basically I am going to tub it and put 15x15 wheels with 31x18.5 tires, and am wondering if I can get away without cutting the frame and narrowing it.
I don't have the truck here to measure it for myself.
Thanks
Old 07-21-2003, 04:00 PM
Canzus's Avatar
a red wool sock on his dinger
I don't think 31's will fit, if you move the spring under
the frame, you might be able to get a 15" wide tire
under there...
Old 07-25-2003, 09:26 AM
Surely someone has had to figure out what the width is between the frame and bed fender lip. I am already going to narrow the rear end, since I already have the wheels and tires. So I don't have the choice on what rear end size I will use, but I just want to know if anyone has tubbed out any Chevy truck WITHOUT narrowing the actual frame. If so, what was the tire width you used?
Thanks again.
Mark
