done that
i did that and it improved a little but it still is very loose, it is at the point where i have to correct the steering wheel every few seconds while driving just doesnt stay put in one direction. if it helps i have a 6inch lift w/35"at,
thanks for your opinion. |
Ah, now that helped. When you have a lift, usually it will get a little bit of play not matter what, but what I did with my 1977 Chevy/GMC pickup that I had, is I bought a stabilizer bar / strut / shock (whatever you want to call it) and sway bars for the front and rear. I decided to try the sway bars and never even put on the stabilizer. You can pickup a nice set of sway bars for under $200 and they HELP. Trust me, I went through the same thing with this set-up :
1977 GMC Sierra Grande 15 6" Sus. Lift 35" Swampers 16" white powder wheels (no-name cheapies Detroit Locker in the rear up to 3.56s Custom built Drive shaft |
loose steering
the frame is solid no cracks, the rubber spacer in good shape, so a sway bar would improve the looseness of the steering? is it still possible it could be a bad steering box?
thanks fellas for the help. ill get to the bottom of this soon enough. |
Well I would suggest you crawl under the truck and have somebody crank the steering back and forth, and see where the "slop" is. That was the only way I found the problem with the Pittman arm ...everything looked fine, but the joint on the end of the Pittman arm was ready to come off! Good Luck! ...Mark
| Recent General Rodding Tech posts with photos |
