Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 78 elky rear end
Old 08-22-2006, 02:10 PM
1982 SS's Avatar
1982 SS 1982 SS is offline
Flamethrower
Last journal entry: More Cooling fan pictures.
If you can find a G-body that originally had a diesel engine, That would have the 8.5" and would be a direct bolt in (open diff 2.73 or lower geared). You can put a lot more to a stock 7.5" than people are willing to admit to. I have friends in the 12's on a 7.5". You use good parts and you can go a long way. I think that the B-body has a wider width drum to drum, and you can find a 9"out of an older fullsize ford. As soon as you go with a different diff, you run into width problems. Happy hunting!
