-   -   78 firebird with a chevy 350 and T-350 neutral start only (http://www.hotrodders.com/forum/78-firebird-chevy-350-t-350-neutral-start-only-216714.html)
addictivewoodworks 03-14-2012 03:28 PM
I have a 78 firebird with a chevy 350 and a TH350. The car only starts in neutral. Once it's started the car does work like normal. The back up lights don't work either. I replaced the safety neutral switch on the column and plugged in the wires. It is a console shift that I have in there and it appears to be the original, not a aftermarket. Can anyone tell me any ideas or how to fix this problem. The only wire I have running to the console is the one gray wire for the lamp.
T-bucket23 03-14-2012 05:14 PM
It is either adjusted wrong or wired wrong. My guess is adjustment as it uses the same wires for park and neutral.
addictivewoodworks 03-14-2012 05:50 PM
neutral start only
How would I adjust it? The linkage on the tranny? I have the assembly manual for the car, but it does not tell me how to adjust that...
T-bucket23 03-15-2012 06:11 AM
Usually the switch mounting or the bracket has slotted mounting points.
