78 firebird with a chevy 350 and T-350 neutral start only - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2012, 04:28 PM
I have a 78 firebird with a chevy 350 and a TH350. The car only starts in neutral. Once it's started the car does work like normal. The back up lights don't work either. I replaced the safety neutral switch on the column and plugged in the wires. It is a console shift that I have in there and it appears to be the original, not a aftermarket. Can anyone tell me any ideas or how to fix this problem. The only wire I have running to the console is the one gray wire for the lamp.
Old 03-14-2012, 06:14 PM
T-bucket23's Avatar
Wiki Edits: 26
It is either adjusted wrong or wired wrong. My guess is adjustment as it uses the same wires for park and neutral.
Chet
Old 03-14-2012, 06:50 PM
neutral start only
How would I adjust it? The linkage on the tranny? I have the assembly manual for the car, but it does not tell me how to adjust that...
Old 03-15-2012, 07:11 AM
T-bucket23's Avatar
Wiki Edits: 26
Usually the switch mounting or the bracket has slotted mounting points.
Chet
T roadster neutral start switch? iron26bkt Electrical 8 10-09-2006 06:34 PM
firebird neutral safety switch zipfactor Electrical 12 07-05-2006 09:21 AM
Quick question about a chevy Neutral SS TL-Iguana Electrical 4 04-20-2006 05:06 PM
Truck won't start unless I play with shifter- neutral relay switch bad? BobbyG-39 Electrical 5 08-11-2004 07:02 PM
Warm start problem SBC/Firebird Kaylah Electrical 4 03-30-2003 02:45 PM
