78 Monte Carlo rear axle bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2010, 03:26 AM
Absolute beginner
Hello guys,
Mary Christmas and Happy New Year.
I have some questions regarding changing rear axle control arm bushings. I read Haynes and Chiltons manuals, that I have to work one control arm at a time.
I will change the bushings on arms ones they are down, but how do I change the bushings on on the axle when it is on car? (see the one shown on the illustration picture) Is there special method or tool?
Also, are all the bushings the same size? I look at online shop I order parts from (rockauto.com), and there is only one size rear bushings.
Thanks for the help,
Ivo
Old 01-01-2010, 07:14 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I have used a ball joint press to do them. The big C-clamp looking type. If you don't need to reuse the sleeves, you can drive them out with a hammer.
Old 01-03-2010, 03:12 AM
Absolute beginner
Hi 1ownerT,
Thanks for the help.
Are all rear control arm bushings the same size?
Regards,
Ivo
Old 01-03-2010, 09:18 AM
1ownerT's Avatar
Wiki Edits: 4
Your car is considered by GM to be a G-body, as far as I have seen they are all the same size for the G-body line. Roughly 78-88 RWD Monte, Regal, Cutlass, Grand Prix, Malibu, Elcamino.
Old 01-03-2010, 10:48 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
If you need to reuse the sleeves and don't have any heavy duty tools like a ball joint press, you can use a 1/4"~5/16" drill bit to drill between the outer and inner sleeves, once you've removed enough rubber, you can pull the inner sleeve out, or knock it out with a punch.
1981 Monte Carlo Rear End whine? alrobjr Transmission - Rearend 6 08-26-2009 10:03 AM
MOnte carlo 79 rear end? rockabilly66 Transmission - Rearend 8 11-22-2007 09:08 AM
Rear Axle Leak Ford 9 inch zonk Transmission - Rearend 5 08-19-2005 06:30 PM
Monte Carlo rear into a Camaro rear? redcamaro4spd Transmission - Rearend 2 12-19-2003 01:16 AM
How about a 6-speed in a 78 monte carlo CrazyT Engine 2 11-24-2002 04:55 PM
