79 350 chevy engine specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2006, 07:20 PM
what is the largest main bearing clerance for a 350 4bolt main that is allowable. had my crank polished and there at
6 thousand clearence is this ok I have built the motor
to 375 hp. thanks dave
Old 02-25-2006, 08:54 PM
Jmark's Avatar
.006? Yikes! That ain't gonna fly. You oil pressure will suck and it probably won't last long before it starts to hammer out the bearings.
It needs to be .0015 to 002. If you need the exact numbers, I can go get my book.
DoubleVision's Avatar
anything under 1 is not enough and anything over 3 is too much.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
S/B 350 What options do i have? (Im pretty new to Engine specs and need some help ple CrazeeAce Engine 4 10-25-2004 04:58 PM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
Looking for specs and info on L99 engine. FIEROZ.COM Engine 4 09-16-2003 01:23 AM
350 chevy engine buildup dran04u Engine 9 06-07-2003 06:39 PM
