79 camaro big brake upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2005, 10:37 AM
New Member
I am installing a 79 camaro sub-frame in my 1940 oldsmobile. I want to use the 5 on 5 bolt pattern wheels I bought. What spindle,caliper and rotor set up should I use?
Old 03-27-2005, 05:23 PM
bullheimer's Avatar
NEVER use credit cards!
i think even with stock camaro parts your gonna be really happy. that would be the cheapest too. if not do like everybody at phr and get the wilwoods. vettebrakes.com has less expensive parts. i've been reading (okay, one article) that claimed the holes in rotors you see will lead to cracking after awhile but i havent seen anything else to verify this. an added expense anyway, with probably not much benefit other than ooh and ahhh.
Old 03-27-2005, 06:51 PM
New Member
Good advice , but I need a 5 on 5 bolt pattern rotor in order to use my wheels.The camaro uses 5 on 4 3/4 pattern. I guess I will just buy new wheels.
Old 03-27-2005, 11:35 PM
Look into B-bodies from about 82-up Caprice Wagons are easy to find in the j/y and all of them have 12" brakes and 5 on 5" bolt pattern. You could also look for a caddy B-body and get the disc brakes for the rear. I know this swap has been done on MANY cars (I have them on my 87 S10) but I don't know for sure that they will "bolt-on" to your f-body. A quick search should find the answer.
Old 03-30-2005, 05:38 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Triaged beat me to it. The B Body Caprice wagons and sedans with a Taxi/Police package with have 12" rotors and 5" lug pattern.
Old 03-30-2005, 07:49 PM
New Member
Thanks for all the info guy's. The project is underway and am installing tubular upper control arms with screw in joints.
big block in 81 camaro rickyc General Rodding Tech 6 10-21-2003 10:05 PM
Anyone looking for a 79 camaro????? the ernster Engine 5 04-24-2003 04:28 PM
Head Liner for 79 camaro with t tops the ernster Interior 2 04-08-2003 06:21 AM
Engine wiring 72 Big Block Camaro Rat Race Engine 4 03-03-2003 11:52 AM
Big Block in Camaro disciple Engine 4 12-13-2002 06:11 PM
