79' Camaro no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2009, 01:16 AM
79' Camaro no spark
Hi, i have a 79' 350 Camaro that i just finished putting a new motor in and i cant for the life of me ( witch doesn't mean much) get spark from the distributor. it has power and ground ( i have tested both) but still nothing. this distributor should be fine i bulled it off my blown motor and it had only 20 min of run-time on it ( brand new same day that the motor went ) any one have any ideas where to start narrowing down the problem?
Old 06-04-2009, 02:40 AM
DoubleVision's Avatar
Make sure the power wire is suppling power, turn the ignition switch to the on position and check it with a meter. If that checks out okay then it could be the coil, the module, or the pickup coil. Check the 3 wires from the distributor to the cap, make sure none of them are broken.
Old 06-04-2009, 06:08 AM
Last journal entry: PICTURE TEST
power
What distributor??
MSD box??
How are you checking for spark??
Keith
Old 06-04-2009, 12:55 PM
i traced the power wire all the way to the HEI's coil and there it stops. none of the wires are broken that was the first thing i checked i have a spare module, i will put it in and see what happens.
Old 06-04-2009, 01:03 PM
Originally Posted by k-star
What distributor??
MSD box??
Keith
just a HEI distributor no MSD and i have tested the spark by just plugging another spark plug in to the spark plug wire and i also have an in-line spark tester and also by timing light.
Old 06-04-2009, 01:28 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You're grounding the plug when checking for spark, yes?
Semper Fi
Old 06-04-2009, 01:48 PM
spark
Are you using a meter??
Do you have 12 volts at the Distributor???
Have you checked the voltage with the starter cranking??
keith
Old 06-04-2009, 02:12 PM
Ok thx for the help i got it sparkin agen i do believe that it was the module,i replaced that and then i got plenty of spark. but now when i turn it over i think i have it to far out of time cause i got a fire-ball out of my carb so i decided to roast some marshmallows wile i think.. and dose any one know how far a 350 should be advanced?
Old 06-04-2009, 02:56 PM
Big Mouse's Avatar
Stroked Z28
Glad you figured it out. I was going to suggest checking for 12V while CRANKING (not just in the "on" position).
Somewhere around 10 initial should get you going. I like my marshmallows lightly browned, not burned. Thx...
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Need Help Installing Side Lexan Windows 79 Camaro jsteve068 Body - Exterior 3 03-27-2006 08:27 AM
pinion to mount angles on a ford 9 in in a 79 camaro Jared Transmission - Rearend 1 09-17-2003 01:11 AM
79 camaro electric fan hook up?? Chadz Electrical 1 07-24-2003 11:19 PM
Head Liner for 79 camaro with t tops the ernster Interior 2 04-08-2003 07:21 AM
