79 camaro swap power to manual brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2006, 06:11 PM
jsteve068's Avatar
i have a 79 camaro with power brakes wanting swap to manual brakes.
this is a drag car . wanting to get rid of the brake booster.
can i use same master cylinder . have been told brake rod will have to be replaced or can i cut it to the right length . thanks steve
Old 01-17-2006, 09:19 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
You wil need a master cyl for manual brakes. The rod is clipped into the manual master cyl and pinned to the pedal. This keeps the rod from falling out when driving. And you know as well as I what will happen if that rod falls out going down the street or track.........
Old 01-17-2006, 09:42 PM
abstruse dutch uncle
The rod also needs to mount higher on the pedal arm for more leverage.
Old 01-17-2006, 09:47 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Master cyl
Manual brakes were an option on that year of Camaro..Go to www.car-part.com and they are available from 20 bucks on up..
OMT
Old 02-18-2006, 06:00 AM
jsteve068's Avatar
all problems fixed . used an 72 corvette manual master cyl. it has deep brake rod hole ( no clips ) . so i reused brake rod from my power booster had to cut about 1in off . frist remove brake pedal drill rod hole 1in higher . reinstall check & cut rod to length
Manual brakes - G body dh79 Suspension - Brakes - Steering 11 07-25-2005 06:04 PM
79 Camaro here with an Idiot for an Owner !! radcojoe Introduce Yourself 3 07-23-2005 12:29 AM
Chevy master cylinder power or manual Eric64 Suspension - Brakes - Steering 7 05-26-2005 04:43 PM
Convert to non power Disc Brakes John J Walton Suspension - Brakes - Steering 2 12-02-2004 06:46 PM
ford 8.8 with camaro disk brakes terror385 Transmission - Rearend 1 05-08-2004 06:20 AM
