Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '79 Chev Rearend
Old 04-02-2002, 03:28 PM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
The real question is how you intend to use it. If you want the look and are not doing it because you are going to mount big tires for the traction, the weaker axle is fine, particularly if it is a one legger. You can get a posi into the proposed rearend, but it will put more stress on the center section and will split the stress between the two axles. But it is more an issue of how much power you make and how firmly you intend to engage it.
