79 commander motor home tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2012, 09:47 PM
truckboy61's Avatar
Friend of has a 79 commander with a 440 motor and would like to swap the tranny for one with over drive could anyone suggest a possible make model and year he might try to find at wrecking yard ?
Old 02-29-2012, 08:02 AM
cranky1's Avatar
Just stuck
I would look at using a trans out of a Dodge diesel but I'm not sure about the bolt pattern for the block. He may have to use an adapter. Other than that, all the factory OD's have a small block bolt pattern and are smaller/weaker. Might take a look at Gear Vendors OD's for it....
Old 02-29-2012, 12:31 PM
boatbob2
Trans........
Hi, a 4L80 trans would work behind that 440.they are a VERY strong trans,BUT,you would PROBABLY have to have an adapter made for it...
Old 07-16-2013, 01:58 PM
truckboy61's Avatar
Looking for tranny that that doesn't require computer system
Old 07-16-2013, 10:01 PM
pricesgarages's Avatar
no chrysler overdrive will bolt up to a big block there are adapters to bolt other units id personally keep the tf 8 thats in it with a heavy vehicle the overdrive would bogg down on mountains
there aways a gear vendor od unit that will bolt up on the back of the origional but very pricy
The Following User Says Thank You to pricesgarages For This Useful Post:
truckboy61 (07-17-2013)
Old 07-18-2013, 06:19 AM
Why do people always think OD will make a vehicle bog down. News flash: at that point the transmission DOWNSHIFTS.
Old 07-18-2013, 10:11 AM
astroracer's Avatar
Look into the Gear Vendors Unit. Keeps the original trans, no cutting or hacking. Keep an eye on eBay and CL. Used units come up often. I got the one I am putting in my Astro for a grand... Nothing wrong with it and it saved a TON of money building and wiring an electronic OD Trans stout enough to live behind the 509... I went with a built 400 using all of the internals from Jakes...
Even if he pays new prices it is an easier swap then a late model OD trans. By the time you get the trans rebuilt and get a wiring harness you will be looking at 2 to 3K, easy...
Mark
The Following User Says Thank You to astroracer For This Useful Post:
truckboy61 (07-18-2013)
Motor/Tranny Swap bosco200 Transmission - Rearend 6 12-09-2010 08:56 PM
92 ford ranger motor,tranny & rear end swap 92fordrangerguy Hotrodding Basics 3 07-25-2009 08:20 PM
chevy pickup motor and tranny swap rebel till death Transmission - Rearend 2 05-29-2009 07:39 PM
Help on motor home sbc 350 rebuild Tea Two Engine 2 05-06-2007 05:28 PM
Home Made Tranny Adapter oddrod Transmission - Rearend 2 06-28-2006 02:43 AM
