'79 dodge bbd carter carb. problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2012, 06:43 PM
I rebuilt my old one barrel carter carb on my dodge plow truck and have it renstalled but for some reason it'll only start with a little gas poured into the carb. Then it'll run fine but if it dies it won't restart without the splash of gas and then I hear it almost boiling inside of the carb. What did I screw up this time? Any help would be great!
Old 11-05-2012, 09:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
With the engine OFF, check to see if there's a stream of gas shooting down into the carb when you open the throttle. If there isn't, something's wrong w/the accelerator pump- either the adjustment, linkage, or the pump piston or the check valves.
The sound you are hearing might be the gas hitting the hot floor of the intake, it is heated by the exhaust manifold and after the engine has run, it'll be hot enough to sizzle raw gas if it's poured into the carb.
Carter / Edelbrock fuel pump & carb problems 67Mustang Al. Hotrodding Basics 16 01-16-2012 07:32 PM
carter carb howardallen Engine 1 07-13-2008 07:21 PM
Help ID a carter carb gator412 Engine 3 05-26-2007 10:13 AM
Any wasy way to clean a Carter BBD's accelerator pumps/jets JerryMopar Engine 13 02-07-2006 06:27 PM
Carter Carb?? 85citation Engine 2 04-20-2005 06:49 AM
