79' dodge van cb300 hydroboost bleeding help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2009, 07:30 AM
We had to repair the steering box, and all of the power steering fluid was drained from the unit in a 79' Dodge cb300 van, so my question is what is the best way to bleed the whole system that's also tied into the brake hydro-boost? do we use regular power steering fluid or ATF?
Old 02-11-2009, 10:36 AM
Use whatever the fluid was called for by the factory. Most cars of the 60s and 70s just use ATF in the PS system.
Bleed it the same as you would any PS system. Jack the front wheels off the ground, fill the pump, start the engine and slowly turn the wheels side-to-side. You probably want to apply the brakes a few times as well. It will groan for quite a while. Stop, turn off the engine, let the truck sit for a while so the fluid stops being foamy, top off, and repeat. My truck took a day or so of driving to completely stop groaning.
Old 02-11-2009, 12:02 PM
ok we tried that method, but the problem we are having is that when you turn to right, it gets real stiff. Going to the left is okay, and that's when your diving it. It does okay right to left while on the jacks. Has anybody had that problem before?
HELP? buying a dodge 2500 van (year: 2000) jojo99 Hotrodding Basics 15 06-10-2008 03:25 PM
Dodge van engine swap Lonestar Engine 3 07-21-2006 08:05 AM
77 dodge b20 van steering questions briansansone Suspension - Brakes - Steering 1 04-13-2006 03:31 PM
Dodge Van overheating Echofive Engine 4 04-17-2004 11:50 AM
Dodge 1987 mini ram van (cargo) - info help? joe99 Engine 8 02-04-2004 11:33 AM
