79 F150 Lift Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 02:11 PM
My79Ford400ciF1504x4's Avatar
Hey, i have a 79 f150 and i was wanting to put a lift under it so i could run 35s and other than the fun factor, decrease my rpms some on the highway. I have read a lot of different things but im looking for some concrete opinions. I have herd that a 3inch body lift is stupid, but i dont really want my shifters shrinking into the floor. If I got taller coil springs out of something in a junk yard, what should i look for to get 3 to 4 inches taller? Also would i have to change out the shocks? Thanks.
Old 04-19-2010, 04:05 PM
Without cutting the fenders you will probably need 4 inches of lift with that much lift u will also need either an adjustable track bar or a drop track bar bracket a drop pitman arm. Either drop radius arm brackets or offset c-bushing and longer shocks or extensions for them. The rear I'd just use blocks and longer u bolts. I've made 2 lifts for 73-79 f150s. One for less than 30 bucks the other one is a lot better. if u want more info on how to do it let me know I'd be glad to help out
And I hate really big body lifts they just seem cheap to me
Old 04-19-2010, 04:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Heres mine with 17/40 Gumbo's. You planning on getting in some mud?
Cole
Name:	Car pics1.jpg
Old 04-19-2010, 05:29 PM
Sweet, so you said that you did an entire lift for 30 dollars? Thats cool, so yeah if you can help me out please do. How do you start?
And yeah i like the mud! Sweet truck.
Old 04-19-2010, 05:45 PM
ya but im a machinist/fabricator if u dont have access to machine tools you will be better off to buy a kit
Old 04-19-2010, 05:47 PM
and add about 80 bucks for the drop pitman arm because i will not recommend what i did to make mine work (it was stupid and dangerous)
Old 04-19-2010, 06:08 PM
Alright, well i live on a farm with my friend and his parents, they have a fair share of tools and machines. Id really like to see what you recommend. I know that im not experienced that much on the suspension system. I know my truck pretty well and i have done a lot of work on it, been through it a few times, but the suspension doesnt seem to be that complicated to me. But the fabrication if within reason shouldnt be too bad. If you dont mind telling me what you recommend it would really help out. Thanks.
Old 04-19-2010, 09:11 PM
whats your budget? ill try to give u a vague idea of what u need to do if u need more info i can email u or something. u can drop the upper coil mount to save money but id suggest that you buy a set of lifted ones from superlift or someplace else. but to drop it u need to grind the rivets holding it on off and pound them through (obviously you need to have the frame on jack stands and the old coils out of the way) then take a peice of 2x4 heavy wall tubing and make a spacer to put under the frame and behind the mount weld it on add gussets and weld every where possible, transfer punch the location of the holes making sure it is in alignment with where it used to be. drill the holes, bolt them on. make a new track arm bracket that looks simmilar to the old one just longer but use 3/8 or even 1/2 in metal. theres alot more torque on it hanging way down and gusset and reinforce everywhere possible. once u look at the radius arm mounts itll be pretty simple to just make some that drops the mounting point down 4'' or use offset c-bushing on the axle housing. BUY A DROP PITMAN ARM dont scimp on your steering thats important. your driveshaft will be too short now u can run it as it is and eventually destroy the splines or you can lengthen it. i think it needs to be about 1'' longer chuck it up in the lathe holding onto the splined end take your cutting tool and with the lathe in a very low gear scribe a line on both ends of the shaft for alighment later then cut the ends off dont destroy them though use the lathe to cut them not to deep. get a new piece of driveshaft tubing the right size cut to length. use the same method as before to scribe a line on both ends press in the old ends making sure the marks line up. weld it back together you no longer have a balance driveshaft but its a big 4x4 anyways new u joints and vibration just come with the teriitory. get new longer brake lines ive used cheaper methods for the brakes before but im not gunna sujest them. then just throw the front end back together i dont think i missed any thing up there. now the back end. take a peice of 2x3 heavy wall tubing dont remember the length weld 3/4 plate to the top and bottom drill a hole .5'' from the center on one side for the alignment pin then flip it drill and ream a hole for a dowel pin the correct size about .5" deep .5'' from center the other way so the hole and pin are offset 1'' to bring your rear axle forward so your driveshaft will be lond enough. press a dowel pin in. make 2 of these. if you can thread on a lathe you can make your own u-bolts thread about 3-4'' in on each end of a peice of high quality round bar i used 4130 thats cut to the right lenghth. bend your u shape in a diacro or something similar. put ur blocks in with the new u bolts. to make the shock spacers take some 3/4'' cold rolled round cut to 4'' or so and tapp both ends so they match the threads on your shocks screw on end of 3/4'' on to your shock then screw a piece of redi rod in the other end and let about 2'' stick out and put all the bushing back on the redi rod end and put in back in the truck.
thats about it in a nutshell i highly suggest u dont do this makin your own suspension parts is dangerous if u are not a good fabricator/machinst. i hope nobody gets mad about the very long post.
Old 04-20-2010, 07:48 AM
Yeah, that's pretty complicated. This truck is also the truck that i drive daily not just a mudder so i cant take it apart for more than a weekend, and i need to be confident that it will not break on the highway. So could i not just get taller coil springs, shocks and a pittman arm, and just block the back and get larger u bolts?
Old 05-15-2013, 09:26 AM
Advice
Got.a 79 f150 just put a 4 inch rough country susp lift on it got the 351m auto found a great deal on a set of 37s does anyone know of they will clear and would I have to go lower in my gearing. Not sure on the stock gearing.
Old 05-15-2013, 01:14 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Can you install the tires for a trial fit? if they fit run the truck and see if the gearing still suits you then make a decsion on changing the gearing as that can get spendy..
Sam
Old 05-15-2013, 05:07 PM
Thanks
Thanks Sam
lift kits for 1964 international scout questions?? 427feracer Suspension - Brakes - Steering 2 12-08-2009 05:15 PM
America's Pride Lift Ampro, whole sad story [long] kgus Garage - Tools 106 04-13-2009 05:59 AM
will 77 model 351w heads take .500 lift buckyr3511 Engine 2 06-04-2008 06:53 PM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 11:28 AM
Need something to lift a truck bed ATMRacerTX Body - Exterior 2 11-13-2003 03:47 PM
