79 ford f150 brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2013, 01:24 PM
79 ford f150 brakes
Just picked up a 79 f-150 with 1 ton axles and 4 wheel dual piston disc brakes. Problem is the brakes work like crap. Pedal goes to the floor. Has stock f150 master cylinder and booster. I replaced MC with one from an f250...no change. Brakes were completely bled and have good fluid flow, but when you try to stop this beast it just wont work. Wondering if that MC and booster is too small to push enough fluid to stop it. What MC and booster should I use? Can I use one off a late model f350?
Old 03-27-2013, 06:24 PM
LATECH's Avatar
Wrong master cylinder on the F 150 body is to blame. It was never for a 4 wheel disc system.
Try the late model F 350 master, if it was for 4 wheel disc. You might as well use the hydra boost also so you have assist to apply those binders.
A larger bore master cylinder will have enough volume to run the 4 wheel discs but may require a stronger assist to apply them to the full stopping capability.
Fact is stranger than Fiction
Old 03-28-2013, 03:58 PM
master cylinder
Do you know if its a direct bolt up replacement to go to the f350 master cylinder
Old 03-28-2013, 05:26 PM
LATECH's Avatar
I would use the booster and master cylinder. Not sure if mods are needed.
77 ford f150 mytoy26@juno.com Suspension - Brakes - Steering 5 12-29-2009 10:49 AM
ford f150 ford f150 Introduce Yourself 2 06-18-2007 09:49 AM
Ford F150 engine Thuggishruggish3000 Engine 4 01-24-2004 03:39 PM
I have a question about ford f150 Thuggishruggish3000 General Rodding Tech 2 12-12-2003 07:45 AM
84 Ford F150 aleblanc Engine 2 11-06-2002 05:01 AM
