79 ford suicide doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2005, 05:59 PM
Sorry if this is a duplicate thread, I just submitted one and it dissapeared into outer space. Has anyone done suicide doors on a 79 Ford pickup, or on another vehicle with heavily rounded sides, where you can't put the hinges on the outer parts of the body? I've been messing with hinge geometry and come up blank.
Old 06-16-2005, 10:03 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
i don't think you can just use a couple hinges with pins on the outside of the body. you'd have to put them at the farthest outside edge of the door and have them lined up plumb with each other. i suppose it would work but it would kind of look like crap. maybe you could get a hinge that goes into the door jamb at the back and has a long arm that kind of slides out of the hinge pocket. i'm at a loss how to describe this, but i think if you had a hinge with a long arm and and curve to it, it would swing the door ahead and out and you wouldn't have to worry about the door hitting the body at the hinge point. hopes this makes some sense.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 06-16-2005, 10:52 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Do a search on the site..there was several threads on this as well as some projects in the journals as to how suicide doors are done..
Good luck..Me I wuld just use the stock hinges and reverse them..
OMT
Old 06-16-2005, 11:53 PM
OMT
If you did that, you would have to open up the rear post so the door can go inside, not very practical. No, there are a number of threads on the subject, do a search.
Old 06-17-2005, 01:25 AM
The hinges would definitly be inside the body. I did a search and ended up at Dr. Chops site, but I couldn't get any pictures. Tech problems? I'll try again tommorrow. The problem I'm having on this truck is that the body is heavily sculpted from factory, and the points at wich I can locate the hinges are limited. The top one is Ok, I figured that one out, but I can't match the pivot point on the lower hinge, so the door will sag outhouse style. I need to figure out how to get the door to kick out farther from the body, so it will open far enough to actually use the door. Is there anything out there with hood hinge type geometry, except designed for a door. Flip front end hinges, maybe?
Old 06-17-2005, 09:30 AM
Ok,if you don't mind me being frank here, nothing personal please don't beat me up on this. I have done a lot of custom mods, from top chops to body sections as well as suicide doors. Suicide doors are VERY difficult to do. You REALLY have to have a good understanding of the geometry to pull it off. There are a zillion "kits" out there to so suicide doors, DON'T BELIEVE THEM, THEY LIE! I have NEVER seen a "kit" that is any more than a couple of junk hinges and some poor instructions. If you can install one of these "kits" and have it work, you can do one from scratch and don't even need the "kit", believe me. Yes, there are "kits" for all kinds of cars for the Lambo style doors or suicide that do work well for a SPECIFIC car or truck. I do not believe there is such a beast for your 79 Ford, I may be wrong. But if the kit says uses anything like the word "Universal" and doesn't say specifically YOUR truck, RUN LIKE THE WIND. Sorry I didn't save the links to show you, but I have seen some of these so called "pro" designed kits that are absolutely DANGEROUS. These MORONS are selling a "kit" with instructions to weld the hinge right to the doors inner skin without any strengthening!!!!! RUN LIKE THE WIND!!!!
This project is over your head, spend the time on something else. You could do all kinds of custom mods with the rear tailgate, front grille and hood, etc. These mods would be seen ALL THE TIME, not JUST when you open a door. Spend your time somewhere else.
Old 06-17-2005, 11:33 PM
Brian you've made enough good points on this site that when you speak I listen, so no offence taken. I wouldn't say I'm over my head, just in a little unfamiliar territory with this body style. I've done the doors before on other cars, and your right they can be a pain in the ^*#. Turns out the guy who owns the truck was hoping to only spend a few hundred $ on the conversion, so there's little point in pursuing this one. I use kit parts to get me in the ballpark sometimes, but it's rare to leave anything unmodified. Thanks for input.
Old 06-18-2005, 09:38 AM
Kurt, thanks for putting up with me. I may have discussed this with you in the past but I don't always remember the names.
I looked at a 79ish Ford truck yesterday at work. I think what you would need to do is move the hinges closer together. It would put some strain on the door but with proper added support it would do the job.
Old 06-18-2005, 10:22 AM
I was stuck inside the box that says the hinges need to be farther apart. I'll keep it in mind if it comes up again.
1939 Ford Deluxe Coupe doors CarGuy70 Body - Exterior 3 09-14-2005 07:00 AM
suicide doors BurgerBob Introduce Yourself 1 01-22-2005 08:34 PM
1934 Ford Doors hammer52 Introduce Yourself 1 11-17-2004 11:09 AM
suicide doors on a 53 ford f100 tgregoire Body - Exterior 0 07-16-2002 10:18 AM
fenders, doors and such 1935 ford beetle9 Body - Exterior 2 03-29-2002 06:18 AM
