Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 79 GM blazer full size with t-350 problems
Old 12-12-2009, 07:28 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
hi,
Check fluid level while in park and warm?
What is the age of the trans? Is it high mileage ?
If fluid is fine as you post, it Sounds like this problem developed as the cold temps arrived this year?
Could be old tired , hard seals inside the trans. Refered to as "morning sickness"
