my mali runs very sluggish till the point where it wants to turn off at about the 2nd gear going into the 3rd. i continue to try n accelerate, it will turn off. does that have to do with the trans.?....ruled out the fuel filters, which were previous suggestions of remedy.car has 305 eng. and 200 trans. THANKS!!
Low float, blocked fuel line ie:kinked or to small, low fuel pressure, vent in fuel tank or blocked float bowl vents. I'd put a fuel pressure gauge a the carb fuel inlet and check the fuel pressure first do this under a load and see what it's got it should be 5-7 lbs.
car is running normal again! thanks to all the suggestions!.....really only changed the 2 fuel filters it had. cant say that's what fixed it because it didnt fix as soon as i changed em but that is all i changed so yea thanks!
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
