Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 79 malibu front caliper INSTALLATION help
Old 06-28-2009, 07:59 PM
rollinheavy's Avatar
rollinheavy rollinheavy is offline
brake bolts
hey you did not mention how far the bolts are sticking out. but if the old pads were wore out and you installed new ones I belive the bolts will stick out a little and as the brakes wear they move back in, just double check your work and make sure you have the right pads and that the pins are seated right. good luck.
