79 malibu front caliper INSTALLATION help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2009, 03:12 PM
wiser626's Avatar
1971 Buick Skylark 350-4
ok everything is done, are the two allen-head caliper mounting bolts supposed slide into the last position they were before removal or be left sticking out after installation? how do i slide em back in, btw they are tightened already. thankssss
Old 06-28-2009, 08:59 PM
rollinheavy's Avatar
brake bolts
hey you did not mention how far the bolts are sticking out. but if the old pads were wore out and you installed new ones I belive the bolts will stick out a little and as the brakes wear they move back in, just double check your work and make sure you have the right pads and that the pins are seated right. good luck.
How many 79 malibu 4-speed cars made? tiresmoke55 Hotrodders' Lounge 22 07-14-2015 04:10 PM
79 malibu buickhotrodder Hotrodders' Lounge 1 05-11-2009 09:38 AM
79 malibu soft brakes mikes68493 Suspension - Brakes - Steering 5 06-12-2007 09:37 PM
79 malibu 79malibu427 Introduce Yourself 2 08-28-2006 02:48 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
