79 malibu soft brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2007, 11:44 AM
i have a 79 malibu with a ford 9 inch i am having problems with getting a good pedal i put gm metric calipers on the rear. do i need a different valving or a residual valve. help!!!!!!!!
Old 06-11-2007, 07:10 PM
cboy's Avatar
Last journal entry: Finished
Are you using the stock proportioning valve? If so, you may have to swap that out for an adjustable valve. The new calipers you put on the rear may require different pressure than your stock units. (I'm assuming that you've done the normal bleeding of the lines to eliminate any air pockets.)
[Edit] Are you using a power booster?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 06-11-2007, 09:34 PM
79 malibu soft pedal
yes i have the stock proportioning valve yet, i have bled the brakes severial times. what kind of adjustiable valve should i look for? the only brake booster i have is the stock one. thanks
Old 06-11-2007, 09:36 PM
T-bucket23's Avatar
Wiki Edits: 26
Did you put the calipers on the correct sides. If not the bleeders will not be at the top and you will never get the air out
Old 06-12-2007, 06:46 AM
cboy's Avatar
Here's one from Speedway that I use.
http://www.speedwaymotors.com/p/1977...ioning%20valve
Old 06-12-2007, 08:37 PM
yes the calipers are on the correct side the calipers and the brackets are the same as a IMCA mod. i looked at a couple adjustable proportioning valves and they say there more for turning the back brakes off could i switch the lines and use residua valves
79 malibu 79malibu427 Introduce Yourself 2 08-28-2006 01:48 PM
79 camaro swap power to manual brakes jsteve068 Suspension - Brakes - Steering 4 02-18-2006 06:00 AM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
Rear end for 79 malibu 79 Malibu327 Transmission - Rearend 21 06-14-2004 03:11 PM
