79 Monte Carlo 3.3 to 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2010, 11:06 AM
Hey everyone, great site, havent seen it till i surfed around for some answers.
So, my son has a 79 Monte, that came with a 3.3 V6, we found a 350 to build and put in it.
The 79 did come with a 305 as a option motor. Are the engine mount brackets the same on the V6 as the 305/350 or will i have issues with the mounting of the 350?
Old 05-27-2010, 07:02 PM
the mounts themselves are not the same, however the V8 mount holes should be on the frame, so it should be a matter of bolting up the new mounts.
montes didn't have 3.3L V6s back then. they had 3.8L and they were crappy engines
Old 05-27-2010, 07:14 PM
Thanks VA, i was looking at the diagram, and the car, looks like it has brackets on the bottom of the crossmember, then the mounts on top, i see the V8 mount holes on the fram too.
Do i move the brackets too, or are there blind nuts in the cross member the bolts screw into?
LOL, everyone says there were no 3.3's, but my emmision sticker on the radiator support shows a 3.3,
Old 05-27-2010, 07:20 PM
the frame mount rubber part bolts to the frame. need the v8 style. no blind nuts under the crossmember. you'll have to use bolts.
i forgot 78 and 79 had an option for a 200 ci V6 which works out to 3.3L. made about 95 hp
Old 05-27-2010, 10:25 PM
yeah, the red headed step child motor
Old 05-27-2010, 11:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You got that right. I didn't know the 200 V6 was put in the Monte in '79- a lot of them had the lowly 267, the 200 is 3/4 of the 267 so RHSC is being kind! lol
But the wiring and plumbing will all be a breeze, the radiator might well cool a V8, but you will definitely want to use a V8 shroud and thermostatic fan clutch.
Some good news is the 200/229 V6 engines used a slightly underdriven pulley set-up as compared to the LWP V8. As long as the cooling system is up to par, this is a nice addition that I've used on SBC V8's through the years. The pulley sets (and those V6 engines they come on) are scarce nowadays, though. Makes me wish I'd have stocked up while they were plentiful.
The tranny may be a TH350, IIRC the TH350C (w/TCC) didn't start until 1980. This will make things easier if you want to change torque converters sometime in the future. Hopefully it's not a TH200 (28-1/4" long).
Old 05-28-2010, 07:15 AM
Good info Cobalt, i will check the pullys and the Transmission
87 monte carlo v-6 to 350 swap? K-1 Engine 2 09-30-2008 03:40 PM
87 Monte Carlo wiring in a 76 350 mightycarlo10 Electrical 9 03-27-2008 11:09 PM
'06 Monte Carlo schnitz Hotrodders' Lounge 31 01-15-2005 11:38 PM
Bring Back the RWD V8 Monte Carlo!! Fragzem Hotrodders' Lounge 18 10-16-2004 11:35 PM
four speed for 79 monte carlo NAIRB Transmission - Rearend 2 09-15-2002 07:52 AM
