79 nova drag car, trans swap question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-19-2011, 08:24 AM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by macdaddy69
the car was spinning very bad ,i bought new set of 28 by 9in goodyear slicks thats when it started breakin stuff we had pinion set at-2 degrees with compitition traction bars and it still twist the drive shaft up aganst the floorboard also the stall is tci and new just seems like 1st gear is useless because u got to shift so quick .i ruined my 350 trans and i have a new glide ready 2 go just hope it dont kill my car
Your car is begging for Cal-Tracs, those will hold the pinion at it's set angle and give a way better launch than "slapper" bars.
Russ
  #17 (permalink)
Old 12-19-2011, 08:30 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Originally Posted by matts37chev
seems like something is wrong (trans mounts or to much axle wrap) if you keep breaking stuff
^^^^^^get this worked out first
then work on your gearing
  #18 (permalink)
Old 12-19-2011, 03:11 PM
79 n0va
went 2 shop last nite,found that my pinion angle was way 2 high,also had broken motor mount and trans mount,i thank all u guys for ur help. ill let yall know how she does this sat nite
  #19 (permalink)
Old 12-19-2011, 06:04 PM
With slicks, you really need to put some cal tracs on that car. Do that and maybe some adjustable shocks and your problems are solved.
  #20 (permalink)
Old 12-19-2011, 06:31 PM
& matts38chev
now we are getting somewhere
get that stuff fixed, then lets look at the strip numbers and see what can be done
  #21 (permalink)
Old 12-20-2011, 05:31 AM
79nova
i have ordered all my parts tru jegs .last nite was lookn 4 caltracks did not see them in book are the called somthing else,where can i find them
  #22 (permalink)
Old 12-20-2011, 08:23 AM
calvertracing.com Read about how they work then get some.
  #23 (permalink)
Old 12-20-2011, 08:26 AM
& matts38chev
the companys' web site is HERE
I searched both jegs and summit quickly and didn't see them, they may not sell them
I am not sure, but I think that THESE are very similar and do the same thing, maybe some can correct me if I am wrong
6.2/350 swap trans question dlwagoner Transmission - Rearend 7 09-28-2011 05:24 PM
78 Nova/86 Monte eng,trans swap 78 Nova Project Transmission - Rearend 5 04-22-2010 03:26 PM
Trans swap question RustyRatRod Transmission - Rearend 1 11-28-2008 01:51 PM
spring and shock setup for drag racing on 73 ss nova? bad2be Transmission - Rearend 3 05-20-2007 06:31 PM
Took Nova to the drag strip first time tonight. 67 Deuce 4 Me Hotrodders' Lounge 17 09-21-2006 02:20 AM
