Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 79 Suburban Ball Joint change Help!!!
Old 01-09-2003, 12:23 PM
Maverick's Avatar
Maverick Maverick is offline
Post
Take a angle grinder and grind down the top part of the rivet. Be careful remember safety first. Once you remove all of the rivet material ONLY!take something to punch them out. Big phillips screw driver and a big hammer. Then the replacements should have nuts and bolts to bolt them in. Good luck!
