79 T/A w/Olds 403 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2007, 09:20 AM
Tyler
79 T/A w/Olds 403
hi guys, i just want to say thanks alot for all the help and advice, if it wasnt for this site i wouldnt be where im at... just have a few more questions..heres what i've done so far,
Its a olds 403 hooked up to a th350 w/stock converter..
#7 olds heads w/ 62cc combustion chambers
comp cam Kit-part # CL42-229-4 advertised 268-268
edelbrock 3711 performer intake
hooker competition headers
flowmaster header back 2.5" exhaust
installed 3.08 rear end
stock qaud jet carb
stock pistons, rods, and crank
so here are my questions..what am i looking at for compression ratio? what should i set my timing advance to in degrees to get the most power from these combos? should i run stock plugs or a colder set? and would it be safe to run nitrous in this motor? or would it shatter the rods?
thanks alot guys...very much appreciated...but if nothing else could you please help me with the timing?? the book says to set it at 20 degrees btdc at 1100 rpm?? is this where i should set it or should i go a bit more? thanks alot again..
Last edited by Rough-Rider; 03-25-2007 at 09:25 AM. Reason: wasnt finished srry...
Old 03-25-2007, 01:51 PM
Mustangsaly's Avatar
stock pistons = stock 403 Olds pistons or stock 30 over cast rebuilder pistons ? ask over at www.realoldspower.com
Old 03-25-2007, 02:00 PM
Tyler
stock meaning the pistons that came with the motor from factory.
hmmm...i'll try and make an account over there, c what happends...but if neone can help please reply..
thanks
Old 03-25-2007, 03:21 PM
you will be happy you ask around over at realoldspower.com if nothing else do a search there for 403s b4 signing up.
Mr. Olds at realoldspower.com knows loves / builds and races 403s heres his web site. http://www.fcrparts.com/
Mustangsaly
Old 03-25-2007, 07:23 PM
Tyler
awesome f-bird, thats what i needed..but the only thing i question on that is this, do i retard the timing 6-8 degrees from the initial 16 degrees btdc, making it 10 degrees btdc? or is it retard the timing from zero degrees making it 6-8 atdc??
if that makes sence..
thanks alot
New '79 T/A Owner Aboard Jrod79TA Introduce Yourself 4 02-26-2007 09:30 PM
Problems modifying my 79 Firebird T/A Arabian Bandit General Rodding Tech 16 05-27-2005 06:20 AM
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
power windows 79 t/a mrhappy66544 Electrical 1 10-07-2004 07:16 AM
78 Nova, 79 T/A rear disc WarChilde Suspension - Brakes - Steering 1 09-03-2003 02:16 PM
